plug change easy!
tjm73
of Omicron Persei 8
Rush, NY
I got my plugs. Sweet! Thanks for the 20% off tip stang72.
stang72
Family of Stangs
tennessee
Yeah got mine there.I got a bad one came up with p0302.Did'nt even have a reciept took it to local advance and they gave me another one.Car runs like a top now.
JEWC_Motorsports
S197 Junkie
Reviving an old thread. I have a 2008 and on Rock Auto it shows black or brown cop boots for spark plug choices. I have the black boot and it shows HT1's will work. Does this mean i have the earlier style heads? I just want to make sure i have everything needed before attempting to change them out.
Edit: found the info i needed from some different search terms.
Jeffk
Thomasville, NC
Wow, I'm glad that I read the entire thread. I was starting to sweat thinking about plugs breaking in my 09.
Yes, I'm a newb to Mustangs.
5spdGT
What did you find? I remember reading something about it a while ago but i cant find it now. I have an 08 also.
JEWC_Motorsports
S197 Junkie
Black boots = old style plugs same plugs as the 05-07
Brown boots = new style plugs No HT1's available.
5spdGT
Thanks im gonna go check on that right now..
Update: Black boots..looks like ill pick up some ht1's and change them out asap.
mikeysgt
Bakersfield, CA
where can i find the ht1's for less than $12 a piece autozone wants for them here? i changed my stock plugs out a few years ago when i was running nitrous for the ht0's. now that i've been completely n/a for a couple years i want to replace them. trying to get a full days tune up for the mustang this weekend (spark plugs, coolant flush, new brake pads and brake fluid flush). just did oil change and fuel filter replacement this past weekend.
mikeysgt
Bakersfield, CA
S197gt07
Newburyport, MA
Yup! I've taken mine out a few times since they went in and they look good.
I would recomend them over the HT1's on price alone
Rockauto.com
$60 for 8 autolite ht1's without the discount or shipping yet.
http://www.rockauto.com/catalog/raframecatalog.php
Total comes to $62.77 shipped for me.
mikeysgt
Bakersfield, CA
Make sure you boomark rockauto they have awesome prices and always have discount codes available.
From what I understand the same company that makes the autolite plugs also makes the new revision motorcraft plugs for ford so they are essentialy the same thing. Now that the motorcraft plug has the coating it shouldn't be an issue with either plug.
Ford had the deisgn revised to have the coated sheath like the autolites, havent heard anything negative about them, I personaly like the autolites and was usign them before the new motrocraft ones came out, but they are really the same plug and you should be fine either way.
mikeysgt
Bakersfield, CA
Ok, just got done swapping my plugs to the ht1's from rockauto. Wasn't scared of breaking any since I had swapped my stock ones for ht0's a few years ago when I was running nitrous. Came out real easy and the car feels a lot better now. Had a question on a couple of things from what i found after pulling them. Anything wrong with the car????
1) the front driver side boot cover came out like this while the rest came out looking normal
This is the plug
2) the front passenger side boot looked normal but the plug came out with some dark oily stuff on it
These are the plugs in order from rear to front passenger side
These are the front plugs (rear on the right to front on the left)
They probably had about 25k miles on them total.
