Possible to have fog lights with high beams?
Discussion in '2005+ Mustang GT 4.6L Tech' started by kstall, Jan 21, 2022.
  1. kstall
    kstall Member
    106
    77
    Anyone know if there is a way to mod the fog lights so they are on with low and high beams?
  2. Juice
    Juice forum member
    4,576
    1,874
    Im only aware of a hack. Requires a jumper wire soldered to the SJB circuit board (the clean way).
    Or, you can just bypass the SJB externally. Take the wire from the foglight switch, and connect it to the wire going to the foglamp relay from the SJB.
    There maybe an SJB programming hack with Forscan, but I am not sure. I could not even find a way to disable bulb out detection. (for LED taillight bulbs)
  3. 07 Boss
    07 Boss Senior Member
    3,638
    804
    Yes you can but it is illegal.
    Monkeyporn and bambam 06 like this.
  4. Juice
    Juice forum member
    4,576
    1,874
    Fails state inspection. If checked...
  5. kstall
    kstall Member
    106
    77
    We dont have inspections here. Sounds like it would be a lot of trouble to fool with?
  6. LikeabossTM
    LikeabossTM forum member
    870
    411
    Why don't you just strap some kc hiliters on the roof and call it done?
    Tony Conti and MasterofDisaster like this.
  7. kstall
    kstall Member
    106
    77
    That is an idea. Maybe even some lights underneath too
    Tizzy and MasterofDisaster like this.
  8. 07 Boss
    3,638
    804
    I can't remember the last time I wanted to turn my fog lights on. In fact my fog light switch currently turns on my headlights. Was a roadside repair that I never have looked into fixing, lol. Been like that for at least a year.
  9. Juice
    Juice forum member
    4,576
    1,874
    Truck guys call it 'Bambi mode'.
  10. kstall
    kstall Member
    106
    77
    We live in a rural area with lots of deer. The more light on the road the better.
    MasterofDisaster and dark steed like this.
  11. 07 Boss
    3,638
    804
    Gotcha.
    But don't deer freeze up when they get lit up? Deer in headlights kinda thing?
  12. Iceman62
    Iceman62 Bullitt 6005
    1,260
    369
    Fog lights, ditch lights, light bars are for 4-wheelers. For your sporty 'stang, invest in a set of quality LEDs or HIDs & they'll be night/day over stock.
  13. WJBertrand
    WJBertrand forum member
    698
    144
    I suppose you could wire in a relay from the headlight high beam wire and rewire the positive leads for the fogs to that instead of the OEM connection. It may also be possible to install a separate switch and relay to control them individually from the headlights.
    As others have mentioned it would be illegal in most states. Having said that, I’ve added aftermarket fog and driving lights to other cars and never been pulled over. California does not do routine vehicle inspections (except for emissions) however. If your state has those it might be an issue.
    Sent from my iPhone using Tapatalk Pro
  14. OX1
    OX1 forum member
    466
    145
    Was able to change it with Forscan on my 17 Fusion Sport, but that architecture is closer to the S550's me thinks. I didn't seem to be able to do much with Forscan on my non premuim S197.
  15. datmbn
    datmbn forum member
    95
    22
    go to the thred in DIY
    High beam in foglights
  16. Juice
    Juice forum member
    4,576
    1,874
    There were two items in the SJB that I found useful.
    I was after bulb out detection after installing LED taillamp bulbs. Had to resort to resistors to get rid of hyperflash.
    So yea, not much user config options.
  17. Pentalab
    Pentalab forum member
    5,027
    971
    The above 2 x methods both work. The 2nd method works better, then the fog lights are totally independent of the headlights.
    WJBertrand likes this.
  18. Stoenr
    Stoenr forum member
    133
    14
    There was a relay kit I bought for mine, but that was 10 years or so ago, don't recall where I got it from. Was easy install tho.
    HOLLYWD69 likes this.
  19. AztroRover
    AztroRover Junior Member
    33
    My mustang came with my fogs that come on with a separate switch. Apparently the previous owner purchased an aftermarket fog light kit off amazon and wired it in but simply wired it directly to the fogs in the grill. Now my stock fog switch does nothing but reaching under the dash there is another switch that turns them on or off and it was wired to turn on and off with the key turned on and turn off when the car is off. So I leave them as DRL lights. I only found out because when I bought it I tried turning them on using the pull on the light switch -nothing happened. Then I hunted down the issue, I thought it was a fuse or something... nope a total separate wiring up and switch. I thought of returning it to factory then thought -I like them on all the time (LED Bulbs)... again there is a switch under the dash to turn them off if I want.
  20. VGMStudios
    VGMStudios Member
    56
    15
    You can't turn on Bambi mode with forscan. I've tried. Only way to do it is wiring it physically.
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
