Status
Not open for further replies.
Berea, Kentucky
Update from my previous times. Nothing changed on the car. Full weight premium 5.0 minus the weld wheels.
Seer
Update from my previous pass:
Best Pass: 11.16 @ 121.39 1.45 60'
-302 4V (Coyote 5.0)
-MT82 6spd Manual
-Nitrous Express Plate
-125 Shot
-3.73
-Mickey Thompson ET Street Radial 295/55/15
Car #: 1531 in both slips.
Fake_Snake
FAUX GT500
Houston, Tx
Is it just my iPad or the first 100 on the list small and then the next sheet huge Tyne every other photo is absent
blackgt87
Hey guys I don't frequent this forum (enough), and I certainly didn't read the first 103 pages of this thread...but I am really happy with how my car ran this past week and I wanted to share. I think I'm up there with the fastest times for my mods.
2012 GT 5.0 MT82
N/A
Factory 3.73's
18" ET Street Radials on (heavier than stock) 18x10" wheels, stock 18's up front.
Car has a JLT CAI, Bama 93 Tune, Lethal O/R X-Pipe, and other than Eibach Pro Kits a completely stock suspension. I think this is a good time for these mods, DA was 713' for this pass.
EDIT: Forgot about the 2% backup thing, I also went [email protected]
AlbertD
Tucson, AZ
Update from my previous best...
11.89 @ 115
-281ci
-TR3650
-N/A
-No boost, No nitrous
-4.56
-M/T ET Drag
Here is the timeslip... Left side
69Mach1-409
South Jersey
New PB at the 10th Annual Andrew Bauer Memorial Nats at Cecil County Drags.
Car 107
RT- .094
60'- 1.661
1/8 ET- 7.427
1/8 MPH- 96.14
1/4 ET- 11.543
1/4 MPH- 120.78
-281ci (stock)
-TR3650 (stock)
-3.55 (stock)
-2.3L Whipple @ 10lbs
-stock clutch
-275/40/R17 M/T ET Street Radials
I think I got everything...
hoovsgt
HoovsGT
virginia
new personal best
Best race time so far is:
1-11-11 VMP
60ft 1.
464
330ft
3.984
1/8 mile 6.
040
MPH 1
19.04
1000ft 7.859
1/4 mile
9.448
MPH 1
40.25
psfracer
billy badass
Valencia, CA
1-11-11 VMP
60ft 1.
464
330ft
3.984
1/8 mile 6.
040
MPH 1
19.04
1000ft 7.859
1/4 mile
9.448
MPH 1
40.25
^^^ the last time I have on the list for you is a 10.66 @ 131. Obviously you changed somethng. List the current set up. Also if you were at the VMP private track day, I am sure you have another timeslip you can post, yes?
hoovsgt
HoovsGT
virginia
here is a link to the video http://hoovsgt.com/aboutus.html
Sean Hyland rotating assembly with 9.1 pistons,manly rods,cobra steel crankPorted and polished valve headsModular Cams Shops stage 3.5 cams and springsMoroso 7 quart oil panT4 T76 8.5 psi Turbo Zex nitrous kit 150 shot ATI C4 trans with reverse valve body and trans brake AC and power steering deleted3 inch open exhaustone piece custom 3 inch steel drive shaft 8.8 Detroit locker diff with 3.73 gears Bogart Rims 15 x 4 front and 15 x 10 rear M/T 28x10.50 slicks and shinnies for race trimQA 1 double adjustable rear shocksQA 1 adjustable front struts with 200 spring coil overs Cervini 4 inch cowl hoodBMR tubular sub frame with solid mounts LMP adjustable rear center upper control arm MotoBlue rear lower control arms LMP adjustable track bar 6 point weld in roll cage with bolt in harness mounts RJS 5 point harness with quick release ProCar race seat Sparco removable steering wheel kit Auto digital gauges BMR adjustable drag bar Steeda fram connectors Manuel steering rack return style fuel system with 5 gallon fuel cell motorsports hotrod computer wiring system
Here is time slip run on no nitrous the same day. 10.89 at 128
me32
Nor Cal
posted a few passes of the night. it was nice a cool. not sure what the DA was, but it was good. this time i ran full weight including Front sway bar and KR strut tower brace. Also i am still running the original Stock 2008 Clutch with 20k on it. running on 285/40 R18 front Good years an 345/35 R18 MT in the rear. new over all best was 10.78 at 129MPH.
2008 GT500
2.3 TVS with 2.59 VMP pulley
E85 with AED Custom Return style fuel system, KB BAP, 80lb FRPP injectors, FRPP 123mm MAF, FRPP 63.5mm TB. shelbly RAD/HE.
FRPP Handling pack, FRPP Drag Pack, FRPP 373 gears
here is the pass of the 10.83
http://www.youtube.com/watch?v=0fI5AjGs8po
Status
