Project Blue Blaze!
kmracer
loosen up that converter and give it more STR and you'll be fine with those gears.
2L8IWON
Va Bch, Va
Not so simple. The crossbars and stuff still have to be welded. It'd not just unbolting the floor plates. As far as backseat. The lil ones will still be able to fit
What if you get in a wreck? Their little faces will smash the bar, unless it's removable to.
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
Any vids and time from NMRA @ Bowling Green ?
Dropped to a 3.55 from the 4.10, 500 ft better air, car picked up .05 to a 10.81. Didn't lose any mph, actually bested my best mph by 1.
Car is also 110 lbs heavier now too than my other run, cage added and left pass seat in
I'm switching to drag radials this week, i think they will put me in the .6's
STEWIE
It's very impressive everything you have done in such a short amount of time!
beefcake
Official Vendor
Bethel, Ohio
it's winter!!!
time to step it up!
thinking, pistons, rods, lowered compression, some sort of fuel system upgrade, maybe a converter, upgraded valvetrain!
RetroGT2006
06 S197 Member
Florida
Damn man, good luck! I can't wait to see next time its out! I wish we had winters so i can leave my car down for a while and work on it/let her get a break from daily duty.
Post pix as you make progress
wbt
What was it that went south? Piston? Ring? No real reason to tear into the motor otherwise. Seemed to be making good HP from those who tuned it...
beefcake
Official Vendor
Bethel, Ohio
Goal is to run all 7 nmra races next year, drive to each race, and drive home. Some of the races are over 1000 miles away.
Goal is to "drive home" from each race and be in the 10.0 range with a dip into the 9's in the fall air on pump gas.
STEVE_POE
coyote powered fr500s
Cincinnati
I know , sell me that epas system and cross member. buy yourself a after market cradle and a manual rack ....... lol ........
Matt D
S197 Pilot
Toronto,Canada
Daaaaaaam . Lookin good brother! Just ordered my cage yesterday... Winter build's are always the best because we have way more time to tear into the car without down time lol
