Proper storage for a shortblock
b00stedgt
New York
I haven't had time to install my shortblock so it has been sitting in my basement. What should I do for storage and how often?
BMWM3
Always Online
Cordova, Tn
i wrapped mine twice in plastic saran wrap.....then storred it in a box with foam.
BullittWow
mod-crazy-fool
The Tri-Cities of Michigan
I have two shortblocks in the basement. Wrap the block up good along with a few dry packs. I also run a dehumidifier in the basement, and keep the block off the floor in case the sump pump fails.
mikeysgt
Bakersfield, CA
i have a shortblock sitting in the garage wrapped up in saran wrap. might be longer than i thought before i start building it, IF i even continue with my plans with the car. Glad i read this.
BlackReign
Just make sure you liberally spray it with WD-40 on EVERY surface, then throw a garbage bag over it and tape it off.
This...especially if you're storing a shortblock in a garage.
Moisture and mud daubers can wreak havoc on a shortblock if you don't WD-40 and seal it up.
