really quick nitrous question/bama tune
amnbassist
Ok so quick question, I have just installed my zex kit and I had it tuned from bama for a 100 shot. I put the 125 shot jets in it. Can I spray with the current tune??? I already have HT0 plugs and the tune loaded in.
DVEST8R
should be ok the difference between 100 and 125 is minimal
KITT
Sell it!
JC TN
25 horsepower isnt worth a risk to me. Might make the difference between 12.00 and 11.99. Answer to your question is yes. An email tune is always on the safe side. Only changes that would made would be timing. rule is pull 2 degrees for every 50 shot so pull 1 degree for the extra 25 with your sct and your good to go. Or run some 110 race fuel and let her rip. I gotta ask why ya put 125 jets in it if ya had a tune for 100 shot? lol
amnbassist
Ok I appreciate it. Wanted to make sure I was good before I turned the arm switch on. =)
amnbassist
The guys who installed it for me put the kit in put those jets
gomb3
My understanding is that w/ the zex kit the 125 shot is actually 100 to the wheels so you should be fine. Someone correct me if I'm wrong
NUTCASE
I did it, kind of.
I had the bama 100hp tune and HT0s. when I went for the 125 shot I went into the tuner and pulled 1* global. everything was fine.
psfracer
billy badass
Valencia, CA
or just put some higher octane gas in it to increase your safety margin....
When you are racing, if it starts to lay down past the 1/8th, get out of it and check your plugs. I don't think it would be a problem though.
choustonls1
Chouston
I have the hT0s and the 100 shot tune from bama and want to up my shot to 125, so I guess I will try what NUTCASE did
