Hollowdweller
- Joined
- Jul 10, 2018
- Posts
- 414
- Reaction score
- 52
Yes…I believe so. I’ve seen posts online and a few guys telling me that it might take more to fill up both but no solid numbers…seen 1.7 to 2.5, sometimes 3 depending on diff cover but that’s usually on threads involving gear swaps, not really complete housing removal.You are filling up the differential and both axles.
Yes I know which hole you’re talking about but no I haven’t personally checked that hole. I took it to a shop today and they reassured me they were checking the hole on the housing. I 100% expected them to tell me oil poured out everywhere, I was blown away when I heard him scream LOW from under the car. I confirmed again that they were checking the hole on the housing and the guy said yes. I believe you, I 100% agree with you, everything is telling me you’re correct….but WTF??? I’ll run it to a different shop tom to confirm…I couldn’t get out of the car at the one I went to today. You think you’re frustrated…ugh lolDude, you can't put that much oil in there without it flowing out of the hole. Quit using the hole on the cover and pull the plug on the front of the diff. I guarantee you you wont get to even 4 qts. Have you even located the right fill plug?
Do you see how low it is on the housing, it's at about the center of the axles. Pull this plug and fill it through the cover. As soon as it starts to come out of the FRONT hole you're done. It's about as basic a process as you can have. Or just put in 2 qts and 4 oz of friction modifier and send it if you can't figure out how to check it properly.
And don't ever go back to that shop again. They're idiots.
Look, it's over filled now. Just pull that front plug and let it drain out till it stops, then put the plug back in and go.
