Removing passenger midline w/ floor Jack?
Matthew J Bailey
I've tried everything I can think of to get my passenger side over axle out. The drivers side slid out between the driveshaft.. The passenger side however doesn't have that much room and its getting caught on the spring. I cant get the car up high enough to get the pipe out and fish the new one through. Any ideas?
retfr8flyr
The Old One
Providence Forge, VA
As you have discovered, you need the car very high to remove the over axle pipes. It is very hard to get the car high enough without a lift. I was never able to do it on jack stands without dropping the rear.
Matthew J Bailey
I wasn't able to get the car high enough but I did take out the bolt on the bottom of the rear right shock and the bolt that holds up the rear sway bar and was able to get it out with ease. Very easy wish I would have did this from the jump.
