Natural1
all around duguder
Any tips or suggestions would be greatly appreciated.
See post #9
I use Acrysol:
I worked in a body shop all through high school and learned a few things.
I use Acrysol:
where do you work ?
Is this what you are talking about? http://decalstickerremover.com/I use a product that you put on the end of an air drill. It is called an eraser wheel, It will not hurt your paint and the rubber wheel will just "burn" off the stripe. On metal it is very easy but on plastic be carefull as you can actually eat the plastic if you keep it in one spot for too long. Hope this will help you if the heat gun is too long for you. Just what our body shop uses. Tom
I parked the car in the sun for about an hour and they peeled off very easily. It took about 15 minutes, I had no residue to remove
