Thanks to the STAC for proposing the move of the S197 Mustang out of STX and into STU. The bump up in tire size (from 265 to 295mm) after this class change is a much needed move. Of course, these heavy solid axle cars need MORE than a 285mm, so we'll be asking for that after this move is official. Also, the long overdue "watts link" updates"are a much needed move (if a bit too late - I still think the SPAC *sshats ruled poorly on this last December). These are steps in the right direction and should encourage the vast numbers of S197 Mustang owners to try STU...
Well, until you dropped the C5 Bomb.
Seriously - adding C5 Corvette into STU - what are you guys smoking???
Trying to compare the C5 Corvette to the McStrut AWD and RWD solid axle cars in STU is a *stretch*. The C5 Corvette has:
+ Aluminum double A-arm front suspension with a composite transverse spring
+ Aluminum 5 link IRS rear suspension with a composite transverse spring
+ A rear mounted transaxle and an aluminum mid-mounted V8
+ Rigid chassis consisting of hydroformed frame rails and a fully composite body
+ A fully flat bottom floor, made of Balsa wood and other composites
+ Room to fit the maximum STU 285mm tire and 11" wide wheels at all 4 corners
+ A curb weight of 3100 pounds in STU trim (proper exhaust headers, titanium Z06 exhaust, racing seats, light wheels and brakes)
+ Low roof height, slippery aerodynamic shape with a wide track width
Does this list of stats sound even remotely like any other car in Street Touring? No? Because it isn't at all like the cars in any Street Touring class. This is bringing the preverbal gun to a knife fight. I don't care that you outlawed the Z06 and FRC (that's just a simple addition down the road), this opens the door for more of the same.
If you add this chassis to STU, they will come, but only in small numbers. Still, the PERCVEIVED EFFECT will be to keep the newly added S197 Mustangs and other RWD cars from even attempting to enter this class. Why? Because whenever you put a well balanced C5 Corvette up against these solid axle 3600 pound RWD cars in an autox setting, the C5 wins. Every time. You are comparing (initially) Super Stock then A Stock to F Stock cars.... it is hard to imagine a farther stretch.
Puff, puff, pass.
