Saleen grill question
Franchi
Senior JR Member....
In a house, with a mouse
Would a 2010 GT, with a Roush front end, fit with a 2010 - 2012 Saleen 4 bar grill? I saw that it wouldn't work on a Shelby, would work for the stock GT and Saleen bumper but no info on Roush.
Got a buddy whose birthday is coming up and I was thinking of getting him that grill as I know he likes it but I'm not sure if it would fit.
Jivefive0
SFV, CA
not sure if this is what you are referring to, but i have a 2012 gt with a roush bumper and saleen grill.
2010-2012 should be the same front ends if i am correct.
Franchi
Jivefive, that looks amazing!
Was install easy? Just follow the instructions and be ok? Any kinda of mocking or up fabrication needed? Does the Saleen grill use the original black plastic outer trim piece?
I just want to make sure if I get it, I can install it. I can follow directions well enough but I'm DEFINATELY not mechanically or handy when it comes to putting stuff together.
Jivefive0
SFV, CA
Thanks bro :)
if he has the roush bumper already, then its just swapping out the fogs lights/grill and surround. that Saleen grill is one whole piece, while the stock setup is 2. I would just be weary on getting the original piece out, because it does take some patience not to break off those tabs.
When i first installed a roush grill i broke off the tabs thinking they were stronger than they were. So just tell him to have a easy hand and eventually it will come loose.
install was a breeze because the grill comes with special clips that you put in after you just fit the grill in. it holds it in place. the new one comes with a push pin which will require drilling. So not sure if he wants to do that or not.
but the main complaint of some people was that the grill didnt sit flush with the bumper in the middle. So they included this push pin to remedy it.
let me know if you have any questions :D
Jed
freddie07
Orlando, FL
Where did you get that sticker in the grill. Mine came with one but it's messed up so I want to get a new one.
