blackjack07
- Joined
- Mar 1, 2021
- Posts
- 44
- Reaction score
- 40
I read the heads up on upcoming CA smog changes and bought an OBD2 to see if I could tell how well my numbers stand up. Tried the OBD out on the Xterra first with no issues. Plugged it into the GT, turned the key to on and immediately heard an unfamiliar, repetitive electric motor sound from the engine bay. Hood was already up and I tried to check to see if it was the IC pump. No spool up. Pulled the cap from the reservoir and no circ. Started the car and waited 10-20 seconds and still no circ. Shut the car off, pulled the OBD out, turned the key back to on and there was no sound. Started the car and let it run about one minute. Checked the res and no circ. Checked the in-line pump fuse, intact. Checked all the 10 and 15 amp fuses in the box, all intact. I am stumped and confused. Timer relay burnt? If so where do I find it? Car ran beautifully last time out with no problems. Any tips or ideas will be greatly appreciated. Thanks in advance!
