SCT X4's now Available!
beefcake
Forced Induction Specialist
Official Vendor
Bethel, Ohio
we still have x3's at a great buy, but here is the link for the new x4's,
http://www.teambeefcakeracing.com/7015.html
of course reg customers know to give us a call
We can also upload our Lund Custom Tunes as well
SCT X4 Handheld Tuner for 1996-2014 FORD Cars & Trucks - Gas & Diesel
Quick Overview
Increases Horsepower & Torque!
The X4 Power Flash arrives Pre-Loaded with DYNO Proven tune files that INCREASE HORSEPOWER and TORQUE! Programming your vehicle with one of SCT's pre-loaded performance or fuel economy tune files is as easy as 1-2-3. Simply plug the OBDII connector into your vehicle's OBDII port, select the pre-loaded tune file using the simple to navigate menu and within minutes the X4 programs your vehicle.
Easy to Read On Screen Data Monitoring With a HUGE Backlit display, the SCT X4 Power Flash makes it EASY to read the Built-In Data Logging or Real Time Monitored Vehicle Data, view popular sensor data such as EGT, Air / Fuel Ratio or any other 0-5 Volt source!
Easy to Install & Easy Return To Stock The X4 Power Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock PCM program. Restoring your vehicle to the stock PCM program is as easy as selecting Return to Stock from the device menu. *This product is not legal for sale or use in California on pollution controlled motor vehicles
Product Features
Increases Horsepower & Torque! Increases your vehicles Horsepower, Torque, Throttle Response and even Fuel Mileage
Full Color Backlit LCD Display Full Color LCD display for easy viewing, day or night.
Reads/Clears DTC Trouble Codes Reads and clears diagnostic trouble codes quickly & easily, saving on expensive diagnostic fees.
Dual Analog Inputs Monitor EGT temps, air-fuel ratio and other popular sensor data.
Installs Quickly & Easily Installs in minutes via your vehicle's ODB-II port
User Adjustable Vehicle Parameters Adjust for common performance bolt-ons such as Cold Air Kits, Exhaust Systems & Gears
Stores 10 Custom Tunes Stores up to 10 custom tune files created by your local SCT Custom Tuning Dealer.
High Speed Datalogging / Monitoring View & record your vehicles PCM data on the LCD screen or on your laptop.
Easy Restoration Back to Stock The X4 Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock program. Restoring your vehicle to the stock PCM program is as easy as selecting "Return to Stock" from the device menu. With all SCT devices, once returned to stock, there is no footprint or trace of the tune in the vehicle's PCM.
Most Popular Vehicles Supported Most popular Ford vehicles supported including 2014 models.
USB Interface Cable Included USB Interface Cable & Livelink Datalogging software included
Built-In Wifi for easy updates Built-in Wifi allows you to easily attach to your local area wireless network to download device updates.
Pre Loaded Tune Adjustable Options
* Adjustable Options vary for each vehicle and are not available on all vehicles
Rear O2's Disabled Disables the Rear O2s and eliminates CEL caused by rear O2 removal.
Fuel Injectors Allows you to adjust for different sized fuel injectors.
CMCV Delete Plates Allows you to disable the CMCV (Charge Motion Control Valve) in your vehicles PCM to prevent a Check Engine light and other issues associated with removing the CMCV plates in your vehicle.
Speed Limiter Allows you to Remove, Increase or Decrease the vehicles speed limiter.
Idle Speed Allows you to Increase or Decrease the vehicles idle speed.
Traction Control Allows you to disable the vehicles Traction Control without using the button in the vehicle.
Spark Modification by RPM Allows you to Add or Remove Timing by RPM Range. (0-2000)(2000-4000)(4000-8000)
WOT Fuel Allows you to Add or Remove Fuel at Wide Open Throttle.
Shift Firmness Control Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLY
Axle Ratio Allow you to set the axle ratio (gear ratio) to correct shift patterns and the speedometer on your vehicle.
Tire Size Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
Aftermarket Intake Allows an aftermarket intake to be run on the vehicle without a Check Engine Light. For Intake Kits that require tuning, this will provide a selection of available intake kits.
Stores Stock Tune Stores a true copy of your vehicle's stock file before programming. Used for warranty repairs and unlocking the programmer.
Supports Custom Tunes Supports and holds custom tunes.
Fan Control Lowers the Temperature at which the Fan turns on.
Rev / RPM Limiter in Drive Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Drive
Rev / RPM Limiter Neutral Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Neutral
WOT Shift Points by Gear Allows you to Increase or Decrease the Wide Open Throttle Shift points of each gear individually.
wckdgt
trenton, ohio
im about to order one here in a week or two, could you pm me a price with a lund tune please, ghost cam? for my SGT
Wile E. Coyote
Rio Rancho, NM
I am about to order one as well, would you mind Pm-ing me a price including the lund tune? Also looking at ordering Bassani's axle back if you have any?
Thank you
james432
east moline IL
Thought no one was doing gost cam?? Dose anyone have a sound clip? And can u get that tune on a x2 and 3?
Boaisy
Dark Knight
Memphis, TN
Ford blocked the ghost cam temporarily, but lifted the ban about a year or two ago. Now almost any tuner can do it upon request.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Does this use a firewire cable for the analog inputs like the x3?
Or is it something more modern?
awesome autocorrect malfunctions brought to you by tapatalk
