Shell URT Advanced.. Northern GA & Northwestern SC
linnE
Getting an order together for the March 23rd track day @ Atlanta Dragway
Let me know if you want in
$80 for 5 gal pail.
Shell Racing Fuel URT Advanced is a high-octane unleaded racing fuel specially formulated by Shell for off-road use. Shell URT Advanced is the highest octane (research + motor octane/2) unleaded racing fuel available on the market today*. Shell URT Advanced Racing Fuel is specially formulated by Shell and is designed to perform in applications normally requiring the use of lead. It contains a race-proven lead replacement additive that protects against exhaust valve seat recession in racing engines.
This fuel contains no oxygen and is formulated using technology that provides detonation resistance previously only possible using lead. This unique technology is developed for engines requiring high octane racing fuel.
Even though it's labeled a "110", the fuel outperforms leaded and unleaded fuels up to 116 octane. The fuel is unique in that it will take more boost and timing than high octane leaded fuels, but it's tougher to "over octane" the car, as UR...T Advanced has a more engineered burn. In other words, you can run more boost and timing with this than you could with your old leaded fuel, but you may not NEED to do that to make more power. It's also safe for Cats and O2 sensors, a huge plus
