shift point discussion thread
05stroker
Never enough power guy!
Bullard Tx.
You have caught may attention.
4:10 gears
28" tire
4r70w trans
1st- 2:84 Shift at 6950
2nd- 1:56 Shift at 6950
3rd- 1:00 Cross the line at 7150
4th- .70 (O/D) N/A
Currently the rpms fall to about 5300 on the shift.
fdjizm
Drag Queen
NY/NJ
Without revving the engine to 8k looks like your shifts are on point.
You'll never fall back to peak torque since your peak torque is all the way at 6200-6300 lol.
BMR Tech
Traction Vendor
Tampa, FL
You will typically want to take a Centri car as high as it'll go, assuming it doesn't start dropping boost.
If it'll safely handle 7500+, 05stroker, you need to be taking it there. On a curve like yours, assuming I am correct that the run was stopped at about 6900....you should be taking it much further. I would bet you would gain 2 tenths by taking it to atleast 7300+ in every gear.
05stroker
Bullard Tx.
It will "safely" handle the power as much as any other well built 3v. I have faith in the build. As for the rpm in every gear that is what I am after here. Sounds like I am on track. I would LOVE a 7500 in each gear pass!
Deez-67
Edmond, Oklahoma
I'm not pro by any means but I concur... take her to the top and bang them quick and hard. I try to pull the next gear at about 6k knowing that by the time I do she is about 6500ish...
"listen to the motor she will tell you when it's time"
Matt D
S197 Pilot
Toronto,Canada
Good thread. It's all about the details.
Been shifting at 7700 As of the last year and a bit :evillaugh:
lindertw
NoVA
so I can wind my stock valve train to 6800+ rpm's with no issue?
:stir:
fdjizm
Drag Queen
NY/NJ
Been to 7k a few times, was puckering up though but no issues. lol
