i tend to see white dust on the SC pulley itself only.. belt looks great
boost gauge goes up to 10PSI without a problem.
i did have a minor issue over the first few days with the sliding idler not being tight enough.. just make sure you push the sliding idler (to the right of the alternator) all the way down and tighten it.
i'd double check your tensioner and make sure you have the 100mm steel smooth idler pulley installed on the driver side.
finally, you mentioned your stumble if you get on it and shift up..
i've suffered from this since day one.. it's actualy the fuel pressure dropping as the load decreases.
with my FP gauge in place, i see it dropping from 55PSI at WOT to 18-20 as i'm shifting gear, then raises slowly back to ~30.
if i get on it before the pressure is back up, the car would fall on its face.
the only solution for me is to shift fast.
i'm still researching the proper solution, as this does seem quite similar to the well documented hesitation that terminator owners with upgraded fuel pump experience (google pprv delete).
