skwerl
tree hugger
Justin said a big part of it is the high compression heads. He said yesterday that my compression must be a lot higher than either of us thought, and he's leery of adding any more timing.
The cams are better than the Hot Rods I had before, but we are still having some driveability issues. Justin said the AF is going between 12-16 at part throttle and he cannot control it. He said he was going to research the issue and figure out what's going on with those heads. Full throttle is no problem though.
Jim, I'm using the 48 or 52 injectors that come from Roush with the TVS2300 stock kit (I bought them from Gerald brand new).
BTW, thank you for the compression ratio information.
It wouldn't help, because then I would just be running out of gear at the top end again. What would help is a shorter 1st gear but that's not happening. I'll just do the best I can with the 27" tire off the line and that should put me at the correct rpm at the finish line.
