Slapping sound when shifting gears
wdrlaw
Columbia, SC
2009 GT 5-speed. Hurst shifter, FRPP handling kit (shocks/springs/struts and stabilizer bars), and Steeda adjustable UCA. When I shift gears there is a pronounced slapping sound from the rear/center, around where the UCA bolts onto the frame. I checked the pinion angle after installing the UCA and it was within spec. Because I had never done it before, though, I took it to a trusted shop to double-check and to make sure I had torqued everything to spec. The sound is literally like someone slapping a butt--a big fat butt like mine. I suspect that something is actually hitting the underbody. First, has anyone else experienced this (the sound, not the butt slap)? Second, if something is hitting the frame how can I tell what it is when the car is moving? Finally, did I trust the shop more than I should have? IOW, should I take it somewhere else? Thanks in advance for your help.
07gts197
Naples, Fl
First, this is in the wrong section.
Second, do you have a video of this sound?
Iceman62
Bullitt 6005
NE
Get underneath the rear w/ creeper & check things out yourself...if this slapping's going on, there's got to be marks in the area(s) of origin.
wdrlaw
Columbia, SC
Sorry. Reposted in 2005+ forum. Old eyes.
No, don't have a video.
Great idea. Will look tomorrow. Thank you!
07 Boss
Sin City
Have you ever replaced the bushing on the top of the diff, where the UCA bolts to?
wdrlaw
Columbia, SC
Yes--Steeda UCA came with new bushings.
@Iceman62: Spent about 20 minutes tonight under the car with a bright LED looking for scrapes, dents, scratches. Nothing other than evidence of very light contact with new jounce stops. The car is about 1-1/2" lower at all four corners--I can no longer fit the jack under it with a hockey puck, unless I drive it onto a 2x10. No visible scratches on diff/axle, UCA, stab or panhard bars, driveshaft, exhaust, or chassis/unibody.
But I couldn't read what forum I originally posted in, so I might not have seen any marks.
@stkjock: Sorry for reposting, won't happen again.
This is a tech topic please keep on topic
