Slim rad fan install and questions
Okay so i instaled the 16'' mishimoto slim fan today to free up some more room for the turbo stuff.
For reference the slim fan has a fan diameter of 15 and 1/2 inches. and flow just under 2000scfm.
The stock fan has a 17" fanblade diameter and flows about the same.
The stock fan and shroud is heavy! I didnt have a scale but the the slim fan weighs at least half of the stocker.
My question is depending on which way i wire the slim it will spin cw or ccw. The stock fan spun cw so i wired the slim to spin cw as well which pulls air through the rad and blows it away towards the engine.
Is this correct? Or should it blow air towards the radiator/front of the car?
Here are some before pics so u can see how much room i cleared up.
Some side by side shots
I reused the stock temp speed controller so the fan will operate high/low like stock for now.
SOme installing pics
All done!
All in all a pretty easy mod! I dropped weight and made alot of room!
2NY
icedesign
oak lawn, IL
awesome mod! Ill have to keep this in mind. I just google'd the fan and found them for $83..you have a certain place to buy one from for cheaper?
2L8IWON
Va Bch, Va
Where's some pics of those brakes man? Nice mod though, love the streamlined look!
Lol there u go matt im sure i dropped 5-7 lbs with this mod as the stock fan and shroud felt to weigh about 15lbs. Wish i had a working scale lol.
Anyone know if i got the fan spinning the right way i wanna make sure. Should it blow onto the rad or pull air through it and away?
07 Boss
Sin City
Which way does the air flow through it when the fan is off? The fan should blow in the same direction.
Cool i wasnt 100% sure, i though it should pull air through as well just wanted to make sure, thanks guys. It makes sense this way other wise it would blow through hot underhood engine air while driving.
2L8IWON
Va Bch, Va
Greg, so the question begs to be asked; when will you be getting your fan ;) save a mod or two for the week I come in, I am dying to wrench on some cars!
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
LOL-how did you know? I am reading about it and don't know if it will help with a stock radiator...guess it can't hurt and it is less weight!
Cheapest I have found for the fan and the mounting kit is $92.08 shipped.
SC boss
watch this!
Desloge Missouri
That is Awesome as I could really use a little more room up front on my car as well!! Thanks for sharing the links!
Shawn
