Snap ring tr3650
Fordeurope00
Hello to all. Just finish rebuild of tr3650. Now I have a small prpblem two os the snap rings broke and I replaced with a similar one but not so think like original one. So can this be a big problem later on or it can go like that??? Thank you...
rocky61201
SoCal
If you think it might be a problem later, best thing is to replace it with the correct one before buttoning up the transmission and installing it in the car. It's a $5 part and not worth the headache of having to do alot of work twice. Most if not all of the lock rings inside the 3650 are one time use anyway. You always bend them a little bit when trying to get the original off.
Contact Stan at this website and he will hook you up with the correct snap rings you need.
http://www.pro-forceperformance.com/
SPeace-ATL
The most critical lock ring is the one on the main shaft that retains the smaller fifth gear. Any stretch, or failure on that one releases that gear to slide down the shaft. That action then proceeds to destroy the drive teeth on both fifth gears. For some reason those rings actually like to fracture...
Stan
86GT351
Sunny South Florida
Contact Promotion Powertrain 954-771-5575 see if they can assist with the correct part
SPeace-ATL
The correct part is Tremec P/N: 1386-139-001
This lock ring is also used in multiple places on the T-45 and T-56.
It appears once in the TR3650 to retain the small driven fifth gear on the output shaft as discussed.
It also comes in the TR3650 "Small Parts Kit" $$$ from Tremec or from Ford.
