lskiller
- Joined
- Apr 11, 2015
- Posts
- 109
- Reaction score
- 0
The kit is very complete, too. Will be 4 weeks or so before it's running. I'll post up numbers when I get 'em. I am upgrading from the Whipple 2.3L that was on my car.
I'm the IAT police!lol, ok. Not surprised to see you post!
Science^^^^^Low IATs are great but my stock F150 has basically ambient IAT's and runs like a 16 second 1/4 mile. ... big whoop.
Depends on where you set all of your timing thresholds. If you raise them up and lean on the e85 cushion it will certainly pull less timimg less often. But at 20+psi don't be surprised if the IAT's get higher than you can account for with e85.Don't tell me it'll pull timing - I tune it myself and race on E85. I know what it'll do and when it'll do it![]()
What are your HP goals with this blower? A 2.8 will get to 800rwhp+. I'm curious how the 3.2 compares.
I'm the IAT police!
Science^^^^^
That said, cooler air is cooler air. Lower IAT's wil make more power even when timing isn't being pulled.
I'm curious to see you run logs.
Almost ready to start blower install. I had oem TTY head bolts and pulled the heads to put ARP studs in.
your kit is way overpriced.
Teaser pic of the blower on my motor. This was just a fitment test.
Looks like you ordered the liquid cooled option. 75mm TB or the bigger 168mm oval? Also interested in the specifics on your motor. Enjoy the project!
Yeah, I think the 3.2 is only available with the liquid cooled front plate.
It's the 75mm twin t/b. Man, that thing is f'n huge. I'll post a pic later. I'm afraid small birds will be sucked out of the sky when I start it.
It's a Brenspeed B302 engine that I installed in December 2011. Stage III FRPP heads w/-450 cams. Runs on E85 most of the time but I run 93 through it maybe 2 months out of the year.
I have a very similar setup with the B302, 2.8 W/75mm, on e85 as well. Currently stock heads and cams though. To give you an idea, I've seen a max of 840rwhp with my 2.8.
The 3.2 is an even bigger blower and will make some serious power. Plus any additional gains from your ported heads/cams.
Better quality products with more features/items cost more money. It's economics 101.
You could have had it for $9000.
