Mustang504
- Joined
- Oct 31, 2013
- Posts
- 52
- Reaction score
- 2
Ok. Because I'm running a blow through style paxton 2200 so it's a little different than your standard Cold Air Intake. I have no bosses to connect to on the charge pipe.Yes, there should be a hose on the passenger side if your hose on the driver's side is still hooked up. You see the vacuum from the manifold draws crankcase gases through your pcv valve but the air you are running through there is coming in unmetered. The hose on the passenger side should draw air from the intake tube after the MAF. Now you have the option of just deleting the system all together, but you must get rid of the hoses from both sides of the motor. If not they both need to be intact.
