stalling issue
nawagner
IA
How old is the fuel filter? Long-shot but could be an inexpensive easy fix.
06silverbullet
orange county, ca
well got the pump swapped out at my cousines shop, didnt even need a lift. just pulled it out through the top slapped the new one in and primmed it and it started right up.
course i went to go put fuel in it and as a i was pumping i noticed it was leaking a pretty good amount of gas. didnt have the locking ring on the front side closest to the front of the car. luckily i had the tools in my car and tapped the ring in place and locked properly...
nothing says fun then working in a puddle of gasoline taping on metal parts with a screwdriver and hammer lol.
Good stuff Vince :) at least one of our cars is running right meow! I won't start tearing mine down until next saturday :(
06silverbullet
orange county, ca
so i'm reviving this thread, my problem has returned after putting in an 07 fuel pump with only 10k miles on it. stalled about 5 times randomly even when just sitting idle mainly. once while crusing.
my questions are:
can a bad fpdm cause the "miles remaining to fill up" be off?
can and does the fpdm intermintently fail when it's dieing?
what are the symptoms of a dieing fpdm?
would a check engine light come up if it was the fpdm?
06silverbullet
orange county, ca
so i finally think i have resolved my stalling issue, the fpdm was dieing.
i noticed something very weird and didnt think it was it til i replaced my fuel pump but..
when my car was filled to say half a tank it would say i only had roughly 85 miles til empty. after finally replacing the fpdm it read that i had almost 150 which is about what it should be. i'm not sure others with a dieing fpdm have had this symptom as i havent seen it talked about so might be a goods heads up for those wondering.
anywho i have an entire new fuel system now basically fpdm, pump ect.
BruceH
BBB Big Bore Boss 322
150 miles to empty? That's not right. Edit: Didn't see the half tank part. There is a chance that the transfer pump isn't working right or isn't hooked up.
06silverbullet
orange county, ca
so i really need some help guys,
after replacing pretty much the entire fuel system i'm still having a stalling issues.
today i couldnt get it to start even after sitting for 30 minutes would crank but not start.
i had it towed home and now its running again
i have no check engine lights.
at this point i have no idea what to other than pawn it off to the dealer which i really dont want to do the car is paid off in two months and it was the first car i bought.
Memphis
I Aim to Misbehave
Vancouver
Just went through an issue similar to what you are describing. Car was stalling like crazy at every stop, throwing odd codes. I threw the book at the thing: Replaced the Alternator and the battery, pulled the throttle body off even though it looked clean and installed a bigger alternator wire. Runs awesome now, no stalling (Knock on wood before I jinx myself). I would look at cleaning the TB first, then battery, then the alternator (And just so you know there ought to be a special places reserved in hell for whatever genius engineer thought of that location for an alternator)
Good luck.
