DieHarder
- Joined
- Nov 9, 2019
- Posts
- 1,862
- Reaction score
- 1,085
Glad it's running. Now try to keep it out of the elements if you can. Check and clean the rubber water drains (one each side) on the lower firewall in the engine bay. Also check the upper window seals. It's often the case that they're clogged or the window seals are bad which allows water to get to the SJB which is the source of the problem. Otherwise, enjoy the car and hopefully symptoms don't reappear.
