Steeda 2011 Tubular Radiator Support
S
Steedagus
Guest
Those of you with 2011-12 GT Mustangs that wanted a light weight radiator support we now have it available.
This radiator support like our previous version has provisions to retain the factory swaybar mounts giving you the option of keeping the factory swaybar in place instead of forcing you to delete it.
Our also retains the factory Z-brace which is on the 2011-newer GT Mustangs. It is a direct bolt on using factory hardware.
Our radiator support saves 9 pounds of weight by itself over the factory support and over 25 pounds with the swaybar removed. It is made out of lightweight chrome moly alloy steel to withstand anything you throw at it, even the punishment of professional road racing without failure.
Comes in a silver metal flake powdercoated finish.
http://www.steeda.com/store/2011-up-mustang-lightweight-radiator-support.html
audidog
Frisco, Tx
Awesome part, great fit and finish and freed up a bunch of room for my procharger pipes.
fdjizm
Drag Queen
NY/NJ
What do you connect to the bottom things sticking out?
audidog
Frisco, Tx
How is the NVH compared to stock?
It should be the same, your not changing any bushings or mounts that increase NVH, it's a simple tubular replacement for the hefty stock unit in the pic below.
