Good post Tiger!
Personally.. In my DD I go with auto, and I've won king of the hill matches with an auto before.. When it truly comes down to it, I love driving a manual trans car when I'm out cruising around, being able to tell the car to be in this gear at this time, and not just a suggestion/etc is great - and I love the clutch/shifter interaction, gotta work together...
Recently drove a Lexus RC-F, full sport mode all assists off.. That trans shifted way faster than I ever could and it held whatever gear I asked of it, even to the point of hammering off the rev limiter (deliberate test)
Gotta say, I would love daily driving that, but still for my weekend 'warrior' car I'd want a manual trans. Too many people nowadays don't even know how to use the 3rd pedal..
Terry... that car is so nice!
In my 2007 I had a built 5R55s with a twin disc PI 3,800 stall. Converted over from the TR3650, to a TR6060, to the TCI auto. Best thing I ever did. Took half a seond of my track time in the 1/4 mile (mostly cuz a need a driver mod) and was a blast to ratchet shift that bad boy on nice days with the windows down.
Planning on doing a notch back built with a 2008 4.6L 3v and a Street Fighter. That's how much I liked it.
Similar to Terry, TCI Rachet shifter,Circle-D converter, Level 10 trans. Take out some shift delay in manual shifting settings and it's a gas..
I would however prefer a manual if street car, more busy more fun. I think I would get tickets with a manual on the street though, auto with hp on the street begs to respect or throws you to the curb real quick.
Ryan, Marc & Kurt,
Reads to me like all of us are on the same line of thinking.
The automatics win races ........
They also in heavy traffic areas far easier to drive and save that left leg.
If like me you have the TCI ratchet shifter you can shift it manually.
Or you can hold it any gear as you like.
Also I think this goes without saying (You have a Custom Tune) then the way it shifts under power is a real blast.
In my case the way my tune is set-up mine holds in each gear to a set RPM or MPH before it shifts in the drive position.
Example mine does not shift to 5th gear (Overdrive) until 60 MPH when in drive.
So it does not SLAM into the next gear at real low RPM's.
I simply put mine in Drive and the tune does it's thing going through the gears.
Even on a drag-strip you simply put it in the drive position (Push the BTN to turn-off the OD) and away you go.
In my case Brent set the tune so that even if I were to forget to turn off the OD (Overdrive) mine will not shift into OD at WOT (Wide-Open-Throttle) until a very high RPM is reached.
Meaning no worries running it at a drag strip at all.
Also he disabled the TC (Traction Control) so it's always off.
Speaking of manual transmissions and our Mustangs.
I had the manual 5-speed in mine for years.
Raced it with the manual.
And certainly played with it on the street.
But here is what I ran into as time marched by and the power level kept increasing.
I ended up with an Exedy 600 series clutch and Exedy lightened flywheel.
The Ford Racing braided stainless hydraulic clutch line.
I can only speak for myself and my personal experience with the above.
It was fun as we know to mess around with it with that configuration for sure.
However it was a bitch on the Ole-Left-Leg in traffic.
Even normal traffic.
Get into the City and stop lights along with bumper to bumper traffic and it was a nightmare at best.
Oh and lets not overlook the on going never ending interstate construction.
Down to 1-Lane and backed up for ever with the above clutch set-up !!!
I will just say to me it was a Bitch.
Plus I don't happen to live out in the middle of No-Man's-Land.
Where I live is constant traffic.
Bottom-line for me changing over to the auto.
I decided to give up the Show-Boating and Playing around with the manual.
Switched to what I posted above and have never-ever wanted to change back.
Yes I'm older and I can see that probably does and did enter into my decision to switch.
But I'll also add that these days and traffic becoming even more so I believe the auto is the better choice if it's the right Automatic Transmission with the right Custom-Tune.
Terry
