Stock Cams??
S197gt07
Newburyport, MA
There is a great list in Jeremy's cam tech thread with a bunch of different specs from all different cams
That should be stickied as well as the fuel injector one.
Davenow
Austin TX
193/216 @ .050" .433/.433 lsa 117.25
What are Hot Rods?
Is there a list anywhere of the specs on the popular cams?
I suppose I could make one... Hmm
*edit* Look what I found :) (Ill add the specs you posted as well)
F150 5.4 3V 176/199 @ .050" .436/.439 lift LSA unknown
4.5 3V 193/216 @ .050" .433/.433 lift LSA 117.25
BBR stage 1 227/233 @ .050" duration, .480/.480 lift, 114 LSA
Comp Cam XFI NSR stage 2 222/235 @.50” duration, .450/.450 lift, 115.5 LSA
Comp Cam XFI VSR stage 1 214/227 @.50” duration, .480/.470, 114 LSA
Comp Cam XFI VSR stage 2 230/232 @.50” duration, .475/.450, 116 LSA
FRPP Hot Rod Cams 221/240 @.50” duration, 472/472 lift, 110 LSA
Thumpers 127010 226/246 @.50" duration, .450/.450 lift, 109 LSA
Mutha Thumpers 127020 234/254 @.50" duration, .450/.450 lift, 109 LSA
Comp Cam NSR Blower grind stage 1 127055 214/231 @.50 duration, .450/.450, 100 LSA
Comp Cam NSR Blower grind Stage 2 127205 222/239 @.50 duration, .450/.450, 116.5 LSA
Anyone know the specs on any of the other common cams? Ill post what I can find. Any requests?
*edited to fix the 205s data*
S197gt07
Newburyport, MA
It doesn't shoot a hole in any theory, since those specs for the 205's are wrong.
The LSA is 116.5, also, no way in hell the stage 1's are a 100 LSA, thats super wrong too.
Davenow
Austin TX
Davenow. Theres is alot of wrong data in your post, 109/110 lsa is less than idea for forced induction. See the cam tech thread for a list of specs.
http://www.s197forum.com/forum/showthread.php?t=62653&highlight=cam+tech+thread
I got the comp cams info off comps web site.
I know I got that one with the 116.5 wrong. I dont know where I got that number, I was looking at the page, I saw the number, and it just didnt make it to my fingers on my keyboard.
As for the less than ideal.
I am a bit tired of people pointing that out, when I very clearly say it. I am not like coming at you specifically with that (so please dont take it that way) , I'm just saying its a little disheartening when I say something, then someone comes and says it to me like I dont know what I am talking about because I dont know it. When I just said it :( They arent giving me some new info lol. I have always said an NA cam isnt IDEAL for a blower, however, and this is what I have been saying, it can, and does work, provided you dont go nuts on the NA cam.
That said, I REALLY dont want to be putting bad data out there. So other than the 205s, which I fixed now, what else is wrong? So that I can go fix it :)
Davenow
Austin TX
Please note the NA cams with 115.5 and 116 LSA.
The reason I point that out is that LSA seems to be the hot-button when people talk about NA vs Blower grinds.
I know one isnt ideal for both applications. However, what I am saying is that both CAN work, with both applications, provided you arent going to a more aggressive cam (more aggressive than mild)
115 lsa for the 127055 cams. I can see what Dave did, he typed the centerline instead of lsa.
Comp has a nice pdf on 3v cams here: http://www.compcams.com/3valve/COMP5-124.pdf
What are Hot Rods?
Comp Cam XFI VSR stage 2230/232 @.50” duration, .475/.450, 116 LSA
What I saw off the top of my head I highlighted in red.
Na cams work great with blowers the stock cams are na. Whe the lsa is too small/tighter it does not work great with boost (cams in the 109-110 range) for many reasons but mainly it restricts flow due to the increase in time both valves are closed. Not a big deal on a na car but with boost its very evident. The only gain here is up top/peak due to increased lift, but power under the curve is affected. 113-116 is more acceptable for a boosted car.
http://www.s197forum.com/forum/showpost.php?p=1158205&postcount=14
streetyme
Hello , I have Anderson Motorsports cams for FI .. The cam # is AF-F43L and the specs are 215/232 @ .050 , advertised duration is 257/274,
timing events -5/35.5 intake 52/0 exhaust lobe lift is .245/.245 gross lift is .495/.495 with a 112 LS. This cam can use stock valve springs,but needs phaser lockouts.
Davenow
Austin TX
What do you think about Hot Rods VS Motha Thumpers power wise, on an NA car?
I love my Hot Rods, but I am always looking to change things around and if the MTs will pick up enough power, then I may consider it.
The other question is how are MTs going to be driveability wise with an Automatic on 4.10s but stock converter? I know the 4.10s will help, but with the stock converter I am concerned about driveability...
I dont even know if I want to bother with it. I am happy with the HRs, but the MTs seem to lope a little harder, and if they make a little more power.....
Davenow
Austin TX
As for the stuff you highlighted, some of it I cut/pasted from other threads, like the 4.5 thing and such. I dont remember if I looked the specs on that other cam up or copied/pasted.
