STR 607 Off set
loots06
Monterey CA
I'm looking at getting new wheels for my car and decided on the STR607 wheels. The off set is 30 in the front/35 in the rear. I'm thinking that offset wouldn't be flush enough or should I look at another option. I really don't understand offset very well so any help would be greatly appreciated.
wckdgt
trenton, ohio
I have the 607's the front offset 35 and the rears are 40mm and it barely pokes w a 305. 40 is the minimum you can run, these cars really need 45 in the back
loots06
Monterey CA
Staggered 20" I want to make sure I get this right. STR607 20" 5x114.3 with a 35 offset in the front and 40 offset in the rear. Front tires are going to be 265 35 20 rear 305 30 20
KonaBlueBryar
youll be fine.
a 10 inch wheel in rear will be fine with a +40 offset, I ran that and it was fine but I had a 285
fronts wont be a problem at all
wckdgt
trenton, ohio
heres some pics I just took of mine to show how deep the concave is and how far they stick out. and some pics of my sgt I had the same wheels on.
well for some reason it will only upload the pics sideways
06 T-RED S/C GT
Carnegie, PA
I'm looking at 305 30 20 for the rear and 265 35 20 in front.
I run 20X9.5" Steeda Spyders with Nitto NT555 G2 275-35-20's as a square setup on all 4 corners.. The offset is 45mm with 7" backspacing and have no clearance issues whatsoever..
KonaBlueBryar
yeah that's fine, I'm running 20X10s with 275/35/20s with a +43 offset and I'm fine. I'm even lowered like 4 inches lol.
loots06
Monterey CA
I got my wheels and they really screwed up the order/offsets. The vendor owned up to the mistake and is shipping the correct wheel.
Sledagent
TIRE SIZE
What tire brand and size are you running? these are 20" correct I'm looking at getting the titanium ones for my 2007 Red fire Cali Special on Monday OR the Fosse Outcast.
