Sway bar delete?
auto02
HUGE member!
Surrency,GA
Anybody running the CHE13D sway bar delete kit on 11-14 cars? It's listed only for 05-10's.
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Not sure what brand that is but the front sway bar delete for the 05-10's will work on the 11+.
kdanner
Austin
Yeah, I can verify that fits 11-up. Aluminum and super light.
mr. anderson
Moore, OK
I've got it on mine and it works great, even better since I mounted the KB intercooler pump to it. I did have to modify it so I could get the mounting bolts on it. FYI it weighs less than 4 pounds.
lchauvin88
Marrero, LA
What does it do?
On my 94 a sway bar delete was just that. I removed it and the end links. I even contemplated doing it on my 11' for when I go to the drag strip.
Greg Hazlett
Chesapeake, VA
Weight reduction and weight transfer; when you put the aftermarket rad support on which is about 3-4 lbs you will pull 25-30lbs off the nose of the car between the stock rad support and the FSB.
Falkinman
New Jersey
I didn't know they were talking about a rad support also. So how weight much does each drop seperately? In other word how much would you lose by just removing the sway bar?
Falkinman
New Jersey
And the rad support is aluminum? How much does that cost? And can you use the stock sway bar with it for the street?
Greg Hazlett
Chesapeake, VA
There are two versions of the rad support delete; UPR/BMR sell one for approx $80 that is 3-4 lbs and replaces the stock rad support/FSB which will reduce the weight on the nose by approx 25 lbs; I think BMR makes a rad support that allows the use of the FSB but 99% of the people who pull the FSB don't notice it is gone after the first time driving it; if you are a course/road racer then obviously this is not for you but for DD/drag racing this is a great inexpensive mod.
Falkinman
New Jersey
Really, you don't notice it?? I'm not a corner carver kind of guy but I did notice a difference after installing my cobra jet springs. Any idea how difficult it would be to remove and install the sway bar for a trip to the drag strip?
mr. anderson
Moore, OK
front brembo package swaybar, endlinks, radiator support, lower engine bay plastic cover, and support bracket and hardware, it's a nice weight reduction:
39.7 pounds. give or take 1/2 lbs.
Falkinman
New Jersey
Thanks for that. I can't find it anywhere on UPRs site. The one on BMRs site is completely different than CHEs
mr. anderson
Moore, OK
I went with the CHE's as stated before, it works well with the intercooler pump assembly. I think new it's 140, I got mine used for 90 shipped.
Greg Hazlett
Chesapeake, VA
Good or bad difference?
The endlinks can be a little bit of a PITA to remove the FSB at the track but doable.
