ClassJ
Powershifter
Anyone run into issues with the Steeda sport springs just being too low in the back especially after they settle?
I really want to swap out the rear springs for something taller but do not know what to try. FRPP springs? Steeda sport rear vert springs?
I have the sport springs and Koni's from Strano and the back of the car just seems too low at this point. When first installed they seemed ok.
I started cut the bump stops a couple times and even then only had .5" of travel to the stop best case with a driver seated. At that point the axle was banging metal to metal under hard bumps and the screws for the bumpstops were hitting the frame under some circumstances.
I put in the FRPP bump stop kit in the back which solved that problem. But the car has nearly zero suspension travel before it is on the bumpstops.
When a driver is in the car, the back of the car is lower than the front.
Car is street use only.
