The "BIG NITROUS" build
05stroker
Never enough power guy!
Bullard Tx.
pretty much, used the fel pro gasket, spent a ton of time in the bowl areas and the short turn radius. The factory exh ports are Very restrictive....much more so than the intake IMO
Agreed, I did mine freehand and they came to the same cc as the FRPP/Livernois High Flow heads. Once you start cutting it is obvious where you need to cut on the exhaust side.
DVEST8R
Yea ive been following ur thread. Your heads look awesome
DVEST8R
Not really much to report.....heads went to machine shop for a 3 angle valve job on Monday and was suppost to be done today but SNOW prevailed......did clean the mani, bolt what I could to the short block, install the coyote injectors, and the TSS oil pump gears
MGT2009
Cant wait to see the results/video.
Ill be buying a plate kit next month. Will be the first time ive tried nitrous. You might be getting some PMs with a lot of newbie questions lol.
DVEST8R
I will help any way I can !
RocketcarX
95% of my weight is fuel
Colorado
On fuel injected engines long runner=tq
On carb engines long runner=hp
On fuel injected engines short runner=hp
On carb engines short runner=tq
It has to due with pulses to bottom of the carb on carb engines vs air pulse at throttle body on efi
Sent from my iPhone 5S
You're completely ignoring plenum volume here, mainly though, I don't think a motor cares how it's fueled as far as torque curves and peak numbers look on a dyno graph.
DVEST8R
Made some progress in my spare time today. Got the oil filter adapter on, oil pump & pick up on, and the water pump.....but more importantly, the heads got done today at the machine shop. Just a simple clean up and a 3 angle valve job! The heads checked good with a straight edge. One important detail I left out earlier, the block was zero decked !
07graygt
I want that bad!! Nitrous outlet quoted me 385 for the parts and 450 for labor. Plus you have to supply you own plates so add another 389. I was thinking about just buying the parts and do it myself. I don't think it would be to hard just time consuming.
07 procharger
Addicted to modding
Red Deer Alberta
I can't remember what mine came out too exactly. I had some other parts on my bill. It's well worth the labour when you stop and look at some of those bends.
They do amazing work. 450 bucks, that's like 4 hours of shop time.
d3vst8r96gt
AZ/WA
I was told 1375 but I don't have ports on my delete plates.
The D3V
DVEST8R
Well, IT LIVES ! Got it together and running yesterday. Don't seem like it lopes as much as I thought it should....tune related maybe?
Picked up some 28x10.5 stiff walls off Craigslist for cheap, no dry rott, still soft, and plenty of life left.
And now, the start up video.....AGAIN I don't think it lopes like it should and I verified the cams I have are the 127500's.....1275019L and 1275029R :mad2:
ArtQ
Alpha, NJ
Turn the idle down to 850- 900. They are not as lopey as hotrods or rockers.
DVEST8R
Idle def needs to be turned down.....I need to order my new fuel pump tomorrow then its off to the dyno. Initial testing will be on the single nozzle wet system that was on the car.
Kipp07GT
Slug Box
York South Carolina
Hell yeah man, im ready to see some action on the strip with the new setup. Whens the first outing and where at? Would like to see this in person.
