The "BIG NITROUS" build
DVEST8R
Where you located at? I'm in colorado so elevation kills my times lol. Did you make that spreader for the engine, it's a pretty cool set up. Looking forward to seeing this finished. I just ordered my kit yesterday. What gap where you running on your plugs?
im in NC, no its a rotunda engine lift bracket. ran the plugs @ .032
DVEST8R
Everything is at the machine shop.....now we wait
DVEST8R
Got the lockouts installed, cleaned bolts and threads, added blue lock tight, tq to 85 in lbs
DVEST8R
My friend Jeremiah had his machine shop handle the machine work and then he assembled the short block. Jeremiah has a much cleaner shop than the shop I work in and he has the proper tools to check bearing clearance, and file fit the rings plus he has built hundreds of fast mod motors.
slo6stang
This is my first post, but I have been following this thread and it is definitely inspiring me for my build.
07graygt
I don't suppose you have a set of charge motion plates laying around. I was wondering if they would work with the frpp manifold. If so I was thinking using the steeda ones for direct port. I just don't want to drill into the frpp manifold.
slo6stang
I would also like to know the answer to this. In my head, it seems like it would work. Sure the intake would be taller at that point, but wouldn't it in theory make the runners longer and in turn make up the low end torque that is supposedly lost when you add the FRPP manifold?
07graygt
Sorry not trying to de rail thread. I don't it would make more torque. From what I understand long runners make more hp and short runners make more tq. But I'm no expert I've just read it in a few places.
SSPSTANGBANGER
LSx Slayer
Plantersville, Tx
On fuel injected engines long runner=tq
On carb engines long runner=hp
On fuel injected engines short runner=hp
On carb engines short runner=tq
It has to due with pulses to bottom of the carb on carb engines vs air pulse at throttle body on efi
Sent from my iPhone 5S
DVEST8R
well I have been busy today porting. heres a few pics
DVEST8R
How many hrs in the heads so far?
8 in the exhaust side only. I may do like modular head shop does for there stage 1 heads and not touch the intake ports, just work the bowls on the intake side and work the exhaust completely
DVEST8R
Tss gears will be here tomorrow on a side note.
05stroker
Never enough power guy!
Bullard Tx.
Did you match the factory gasket for the exhaust side?
DVEST8R
pretty much, used the fel pro gasket, spent a ton of time in the bowl areas and the short turn radius. The factory exh ports are Very restrictive....much more so than the intake IMO
