The Devils Reject
gizmo5
Italian between my legs
Remind me again why you moved the CC all the way to the drivers side that evacuates the passenger side PVC system? That's a lot of hose I would have left off but maybe I missed something in your rationale.
The Paxton kit radiator reservoir goes in the spot where the Moroso can does. The bracket that comes with it is meant for the pass side, but I went ahead and put it in the vise to tweak it and make it mount on the other side.
It's still doing its job, but now the S/Cs reservoir and CC will all play nice together, and the driver side uses the provided check valve from the kit. :thumb2:
GrnBullitt08
Dale Jr
Northwest Indiana
That's the only thing I don't like about the Vortech/Paxton kits. Clutters the engine bay. I had the same issues with my 08' Bullitt and the Paxton Novi 2200SL System.
jpac811
Slow 3v
Sumter, SC/ Tampa, FL
some good sized drag radials or you will just be making nice smoke shows. Im going from 275/40 r18 Nitto 555 to MT ET Streets II 305/35 R18 for the street and some 15in MTs for the strip.
gizmo5
Airaid Synthamax filter FINALLY showed up!!!! Time to give her a nice and "easy" test drive.....
gizmo5
Mother of boost... Forgive me for I have sinned like a mother fucker tonight.............
LOL
Just drove around for about an hour, having some fun
gizmo5
did you log it before you were jumping on it?
No, but I'm running the super safe Paxton tune right now, when Lund gets me my base tune for the remote sessions, I'm gonna be a good boy and baby it till it's all sorted out.
It feels strong and smooth right now! It just pulls and pulls, and then pulls some more... lol
gizmo5
So, I was getting a nice squeal under the hood that freaked me out for a second... Popped the hood, conducted investigation, found the culprit.
My PCV hoses were collapsing on me and making a funny wet fart noise. And we all know you cant trust a wet fart... :2g1c:
SO, off to home depot I went looking for compression springs, they didn't have any so I got the next best thing, extension springs. I just stretched them out and cut them to length, inserted them in the hose, and boom, problem solved. It will now take an act of God to suck those things shut... Or and act of [your moms name here] :boobies:
And because nobody likes a post without pictures (kinda same category as a wet fart) here you go
I did this one by hand and it came out uneven, ended up fixing it little by little to make it pretty
Then, I got smart... This ended up being the best way to get an even uniform stretch
Once stretched, insert all the way to the other end, and trim to length
gizmo5
Next... Im thinking BMR K member, and BMR relocation brackets...
GTOdude
Farming goats/ponies
Merced CA
Ida never thought of that.. good job. :thumb2:
