The Devils Reject
gizmo5
Italian between my legs
I was incorrect, he first went to 75lb injectors, and it wasnt enough, he was advised to buy the Vortech BAP, that with the 75's helped him. Like I said to you in an earlier discussion, you do not need ID1000s for your car, you will need a new short block before you need ID1000s. You will need a 72lb injector though. Buying the ID's is not a a bad thing though since they are a good injector. Not saying the modified 47's into 72's are not, since they are good as well.
So, ID1000s with no BAP? Or should I still need a BAP. Both seems like waaay overkill...
Seer
No, no it isn't. I do not feel 1000cc injectors (this is in fact overkill) are needed, but something in the 60lb range would be.
MindIfISmoke?
Wrecking Crew
Puyallup, WA
Go 72# with bap... i am making 670 whp on pump with a 2012... no fueling issues
Sent from my DROID RAZR using Tapatalk 2
gizmo5
Any particular 72 injectors you guys are fond of? Also, which BAP do you think is best?
Seer
Whichever BAP you buy, do not wire the pressure switch in, run it all the time. It gives a weird lag to the fueling. A lot of guys like the Vortech BAP, I prefer the KB BAP, there is also the unit from JMS now too, but I do not know much about it.
I run the KB Dual Competition (20.5v) BAP. But I feel all you'd need is a standard (18.5v) single bap.
The 2011+ Mustangs have the ability to overvolt their pumps in the tune up a few volts, but still typically is not enough past 550rwhp or so.
gizmo5
So... After tons of chit chat and phone calls... This is about as sure as the list is gonna get. I want room to pulley down in the future too, sooo...
KB BAP, ID1000's, Lethal ORH, Clutch line upgrade, BMR K member, BMR Relocation brackets, Aeroforce gauge with boost sensor, and Roush gauge pod.
THEN Lund can tune it. Sound good?
Kenaizer
Denver
Haha sounds like a bad ass list. I wonder how much longer it'll get when all is said and done?
gizmo5
BMR K member and BMR relocation brackets ordered. Beefcake FTW!
Next week, ID1000's, BAP, and Letahl H pipe...
Just gotta go hustle some more crack... :crazy:
gizmo5
Are you keeping the stock exhaust manifolds?
Yeah, I don't think it's necessary for me to change them until I build the motor. I can get the power I want without spending a G on LTs. Hell, a $75 pulley will give me more POWA for the $. :thumb2:
gizmo5
Just because it sounds cool and everyone likes videos. Not to mention I figured out YouTube and can now upload vids in a few seconds to share with you guys :thumb2:
