ticking
mustangflanagan
south jersey
Car developed a tick when the car warms up a bit. its not injector ticking sounds like the alternator or something in the middle. It goes away after i drive the car a little bit. Any ideas
Could be a vac leak, make sure the spark plugs are all seated and none backed out. 45psi oil pressure at idle is healthy.
dans08gt
the white ghost
is it a 4.6? if so i had a ticking noise that turned out to be a lash adjuster. from what I've read this is a common problem with the 4.6
mustangflanagan
south jersey
Well it might be time to take it to the shop. Damn thing does it when the car warms up then after driving it 5 mins it goes away wtf
arabbit
12 inch member
If its a coyote, its normal, don't go chasing it down.
dans08gt
the white ghost
Like I said earlier it's sounds like a lash adj (lifter). Mine would come and go and sometimes go days without making a noise. There was no pattern to it. Just figure out which side and replace all of them. That's what the dealer did for me.
mustangflanagan
south jersey
Would it do it if u let the rpms get real low? Mine does it its more distinct. When i do
weather man
Persistence Is A Bitch
MN
A concise sig line does help your fellow members out.
