Tire pressure gauges ?
Pentalab
What are folks using these days, that is accurate ? I can't seem to find gauges that correlate. They appear to be all over the map. Is there any way to calibrate them ?
frank s
at Play
Paradise
csamsh
OKC
It doesn't matter what the gauge says. You really only care about relative pressures anyway...tire wear/temp/lap time should just make you go "up" or "down" in pressure.
That being said, I use a longacre gauge and it's pretty good- it matches the calibrated NIST gauges I use for work within a psi or so.
Department Of Boost
Alpha Geek
When I was racing, and a 1/4psi mattered I went through about every gauge out there before I landed on this one. Best by far.
http://www.amazon.com/Motion-Pro-08-0402-Pressure-Gauge/dp/B001AWIHHK
