gil_t2
Love Nitro in the Morning
I know that the T56 Mag is better. The mag uses a little bit bigger bearing but the shafts are the same size. If you took a 6060 and upgraded the sync-o's and replaced the plastic shift forks inserts with the brass. you could have a great trans for alot less. Both are rated to 700 ft lbs. I did it with my 6060, my complete conversion only cost $1790.00. The only thing i want to do now is MGW shifter and Quick time BH. If i had an 8oo RWHP car i would want to wait for the T56, but i don't. BTW I have had them apart and compared them. The Dodge version of the 6060,s main case uses the larger bearings, If i were to do another swap i would start with the 2010 Dodge Challenger trans, you need to replace the input shaft with the shorter Ford T56, it all ready has mid-plate, you just need to fab a rear mount. It all so had two shifter mounts.
