Hello,
I am in the process of finishing up a new stroker build with a 76mm turbo, MMR turbo grind cams and ported heads. I currently have a tune setup for the stock cams. Will this tune be ok to run with the new cams? I was wondering if the valve timing would be different for this tune with the stock cam lift of .450 vs the .500 lift on the turbo cams. I do not want to hit a piston. Please advise.
Thanks
Thanks
