psycho bob
FISTER
well following the instruction for the electrical diag. i was checking resistance to the tps. the minimum on a couple of them was 700 and i was only getting 280 +/-. if i did it correctly i need a new tps.
DUDE you have the throttle position sensor plug, gray with red tab, and the fuel pressure sensor plug, solid gray backwards. .CHeck and see bet you money. don't be surpised if your sensors aint screwed up now cause I did this when i first put my motor in and had to buy a new tps. Mine wouldn't idle, and it throwed the same exact codes you have now.
