Boy, I thought I responded to this already, but it doesn't seem to be here...
Oh well, here goes again...
just curious what capabilities it would have, from what I can read on their website you should be able to do a complete tune on a car ...
You most certainly can - the issue is that you need to know what you are doing with it. I started from understanding how the engine works having built them and tuned carb'd engines before. That and having written embedded software. So, all I had to do was work from that to how it is presented in the software and the tune itself...
The MAF curve is relatively straight forward if you have a wideband O2 sensor. Doing pulls on the street is not a great idea, though.... The dyno or the track is a better place to tune the full MAF curve, your data logs on the street end up being erratic and incomplete as its pretty tough to getom from 1500-6500 RPMs on the street without doing something stupid or geting a big ticket... Your mileage may vary... (literally).
Turning things on and off like CMCVs, O2s and fans is pretty straight forward, that's what I do more often than not - adjust for changes to the car that don't require a "tune", just binary yes/no stuff.
There are quite a few aspects of the Ford tune that are not really intended for human consumption (since its a computer), so they are not always intuitive and there are scaling/conversions you have to be aware of... And things like yes/no flags that aren't always "0" or "1".
Injectors and timing are obviously harder - that's where the expertise comes in (that and jumping to a different, larger, MAF housing). You need to "just know" some things that you won't easily figure out just looking at the software or even if you understand how the car works - you still have to figure out how the PCM accomplishes that...
It's a very useful tool, but if you aren't already familiar with tuning, I'm not sure if it would be worth it unless you have someone to teach you. I had an engine I was replacing very soon to practice and some help which was nice. You can really hurt the car if you screw up...
There is a forum for help that is pretty good, but it is by permission only as there are propretary non-disclosure requirements to buying the tool which is why you don't see a lot of discussion on it.
were there any software issues? what os are you running it with?
XP - no issues, there were some vista issues early on, but as I understand those are ironed out for most...
I have 2 different maf sizes I use, 3 different pulleys to play with, water/meth injection, waiting on an intercooler design, and would like to see the difference from 91 to 100 octane, by my best estimate that is a hell of a lot of dyno time and seat time, at an average of 125 an hour I am willing to educate myself the hard way.
That's where things get a little hairy... Knowing what you can get away with in octane land and timing is tricky. Even having the SCT software I defer to "experts" on such things... That just comes from the school of "hard knocks" (pun intended).
new/different MAFs can also be tricky unless you know where to start. Get it wrong enough and the car just won't start and you get no data at all....
You can get there and you will learn a lot, but for $50-100 you can have someone set you up with a base tune via email for such things. They make a box you can work within (i.e. don't mess with their timing tables).
Learning the "hard way" with FI is an expensive way. Get it wrong and you pop the engine...
Be careful...
I wish Ford just sold you the car with that stuff, but understand the reality that most people would blow up the car in the first week and there is no way the EPA would let them - heck, I am surprised the EPA hasn't made it impossible to tune them in the first place...
Owning this software is not a replacement for an experienced tuner - it will take you a long time and likely a damaged car with FI to get there by yourself... That said, these cars are now well enough understood that you can work with some of the mail-order tune vendors to get base tunes that are completely open that you can manipulate in SCT ProRacer... That's the route I have gone.
