retfr8flyr
The Old One
Does sound like an air pocket. I know these systems are a bear to get all the air pockets out.
Earl
Earl
Earl
Jack the front of the car up take off the coolant cap turn the heater on full blast! Let the car warm up! AIr pockets are known for chilling in the heater core.
Used the new machine
Still running up to 220 with the air on
Im wondering if my turbo air cooler is too high? Blocking air flow?
here is a pick on hight when we mocked it up.
Ill be doing the Drock burp tonight
Im getting lost
I don't think that's it. My intercooler is blocking 100% of the lower grill and I don't have issues.
You will not see much movement from the coolant tank unless you purge a air bubble, water dosnt really run thru that tank. It just sits there until the coolant expands and shrinks from the heat/cold. All that will happen is the level will go up/down slightly.
If you want to test the thermostat you can always throw it in a pot on the stove.
I used the cyclone fans and they work decent. I'm going back to a stock 2013 gt500 fan.
They don't usually stick closed. Haven't you driven the car? A stuck thermostat would make the car run hot very quick.
My hose sits right by my turbo and I haven't had a problem. Even in 100 degree weather. Sometimes its the little things that make a difference. Maybe it is the tstat.OK then maybe thats ok then, I was think it may be the ebay fans are not enough, but Fuel is running them with no issues?
230 head temp in the driveway seems a bit much to me. and yes I have benn driving the car, it worse with the air cond on
Maybe Im just over thinking this tho?
Or maybe I still have air trapped somewhere.
My reservoir hose goes about 2 inches in front of the turbo about halfway up the radiator, that couldnt be it could it, heat from the turbo is heating the water in the hose?
Did you run the heater on full blast to your head/feet direction with the cap off all the way up to temp and let it sit for a bit?
