Under drive pulley install?
KryptonKnight
Fallston, MD
I have a set of Steeda UDP. Any tips, tricks, or suggestions for me.
I do not have access to a lift so I will be on my back.
Is this a job for a nu-bie, like remove belt, unbolt, bolt new pulleys, replace belt?
mustangtcs
Pennsylvania
I did this in a half an hr including putting a cai on with no lift. I did have to install a tighter belt though. I frayed the original belt within an hr.
Riptide
Will work for Mustang.
Montucky
I've seen DIY guides on this that make this easy peasy. Do a search. I know its a dirty name around here but "tacobill" has a How To on MF that is worth lookin at.
Sent from my iPhone using Tapatwat
First tip, use the search function! There are tons of threads with all this info you are looking for.
KryptonKnight
Fallston, MD
Thanks for the help. I did a search while I was in the DIY and went through all 10 pages without success. I guess I do not know how to use the search correctly or at least effectively.
Riptide
Montucky
Goto mustangforums and find the tacobill writeup its in the stickies over there.
