Why would you have to upgrade the fuel hat when wanting to run the 8an line?
Yeah you can retain the oem fitting as its barbed and fits right inside the 8an line and then clamp it which is want I have done on a few cars. You can also use that same Russel's efi fitting, the inlet and outlet on the oem fuel filter is the same as the fuel hat outlet.
Your method would still be a bit cheaper though.
I found the post. I really don't like using a hose clamp to retain the hose on the barbed fitting in an EFI system
guess it works though...
probably not a whole lot different than the way the OEM fitting is retained
Do what was the benefit? Did you see a decrease in FPDC or something?
Looks nice though... I'd would totally do this also when I am ready to replace my fuel rails.
As I mentioned in a previous post, for this stage of the fuel line upgrade I wanted to upgrade from the OEM fuel filter to Fore Innovation's fuel filter without having to replace the OEM hard line from the fuel hat to the inlet of the fuel filter. Very easy to do.
I chose to completely remove the OEM hard line from the OEM fuel filter to the driver's side fender well, which had already been updated with a 8 AN line to the fuel rails. This is not necessary but I felt it made for a cleaner installation
Next step was to modify the OEM fuel filter mounting bracket. This consisted of 2 steps:
- cutting a relief in the mounting bracket as the OEM filter is 2.00" OD and the Fore Innovation's fuel filter is 2.20"
- drilling a new hole mounting hole for the bracket .75" forward of the original mounting hole. This allows the bracket to be moved .75" forward so the OEM EFI fitting mates up with the inlet of the Fore Innovation's fuel filter
I procured all parts from Jeremy @ S&H Performance with the exception of the -10 ORB x -8 ORB adapter and -10 Viton seal
remounted the Fore Innovation's fuel filter in the OEM bracket
finished by routing the -8 AN hose up to the Fore Innovation's fuel rails
I'm sure some day I'll upgrade the OEM fuel line from the fuel hat to the inlet of the fuel filter but that is a project for another day
What size is the quick disconnect piece? I can't seem to find it on summit.
Would there be any problems going with -10 an line from fuel filter to rail?
Problems, no. Its largely overkill though unless your going for 1000rwhp +.
