video & sound of comp cams stage iii -127650
S
Sini5ter08
Guest
That is very odd......Your car sounds like it is out of breath.
viciousride
Needing more power!
Miami, FL
Need to raise the idle RPM closer to 1K, but in any case it still sounds good.
BTW, someone will mention about embedding the vid, so here you go...
Daniel Day
Resident psychopath
Newnan, GA
Yeah, you definitely need to get that tune right. No offense, but this is what a cammed 3V should sound like. :thumb2:
toorbeenee
turbine lunatic
dubai
no this is the way the car is when cold,,,after it warms up it sound little different,,,i tune it my self since i have a stand alone ecu,,,but thanks guys
toorbeenee
turbine lunatic
dubai
I think it sounds good, what all did you have to upgrade for that cam?
thanks, livernois springs with comp cams retainer,,comp cams springs broke off
is that even a gt500? sounds like it's going to stall.
only on cold starts, i have an idle controler from 1990 mustang that was not working very well, i had to adjust it little
thank you for embedding the video for me:thumb2:,,,,after the car heats up rpm range will between 900~1100
sounds like it needs a tune update...the idle hunting would drive me nuts
i love the idle when she is cold,,,reminds me of old hotrods with mega blower:thumb2:
no offense taken, your car sound very good too,,,all the best
toorbeenee
turbine lunatic
dubai
have you dynoed the car yet? I'll assume not since you do you own tuning but ya never know.
yes i did,,, 475hp on 9psi,,,but i had some loose bolts in the intake manifold,,i am going back to the dyno next week to re tune since 475 is not right with all the things i have in the car,this time ill print out the sheet to post it
NotQuik
I can't drive
Central Florida
what supercharger/turbo do you have? I assumed you were n/a but missed the intercooler in your sig.
Blxcklist
Hi Im Justin
Idaho
I actually think it sounds bad ass. I bet it drives like ass until 4k though then hauls ass
toorbeenee
turbine lunatic
dubai
thanks,
i just took the motor out,,,these cams are going out i am having a very hard time with them, roller rockers breaking on high rpm since i have replaced the springs with livernois springs(those springs not made for high lift cams),,,i have spoken to john@bbr and i think i am getting a set of there stage ii cams.
i hate taking them,,,,but i love driving that car
btw my last dyno numbers were [email protected] psi,,,,not too bad
