VMP private track rental Oct 28th
Coderedsaleen
Powered by 03 Venom
Chesapeake, VA
808svt
^^^I like that one. Just second day aired some slicks, I hope I get to use them.
808svt
Yeah, I got a good deal. LOL Its not so much I can't afford stuff I just don't like to spend money.
808svt
That's OK Tim, my wife does a good enough job for all of us. LOL
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Nice...but....how are you going to close the hood.....jus sayin.....? Snorkle action?
Cuttin a hole in the hood! lol
Nah i went ahead and put it on like that to start the car. The drain was leaking at the oil pan like luke's was, so I rtv'd the shit out of it and now its all good.
Took me a bit to get it to fit with the bigger compressor cover. Here is the final result. Gonna have to make a new support bracket for it.
As you can see its really close to the idle pulley.
Yeah its about 1/8" inch away, once i fab up a support bracket it will pull the turbo up and away a little more. Took it for a test drive lots of condesation in the pipes from sitting for 4 weeks but after all that worked is way out it looks good just a little bit of smoke still from residual oil most likely, gonna drive it to work tommorow and check it out again.
LAllison20
Chesapeake, VA
evry so often mine will smoke a little when i get going but it will stop. what causes that? oil in the turbo?
At start up you see 90-100psi of oil pressure, once the car warms up it dips down to 30-40 psi at idle. So at start up you will get a little oil past the seals, thats normal.
