95ragtop
I have a V3 Vortech Si (no tapping oil lines) with 25k miles on it. It has a Steeda heat exchanger, new intercooler pump 2k miles ago, a 3.25" pulley, Kenne Bell Boost a Pump, Diablo MAFia, and 39lbs injectors. There was zero wear in the head unit and zero shaft play. With a Reichard Racing 3.4" pulley, long tubes, and C&L intake manifold I made 500rwhp at 10psi. Head unit has been drained and will come with 1 bottle of supercharger oil.
For 2005-2006 Ford used a different cooling system and you will need to buy a coolant crossover from Vortech and a coolant hose.
All the major components are here, but there are several small items you will need to make it a complete kit.
T-vacuum connector for the Mini Race Bypass Valve
Diablo/SCT Tuner
I recommend installing a IAT sensor in your manifold
A 0.093 spacer behind one of the pulleys on the head unit bracket (got sent wrong one, working on getting right one)
Valve cover breathers
When I bought the kit I had to improvise on a few things: the brass fitting is for connecting the coolant reservoir and a bottom coolant line, the clip for the electrical connector at the intercooler pump broke so I just used electrical tape, and I didn't get bolts for mounting the heat exchanger and the ones I used stripped the bumper support nuts. I can give you the ones I used or just go to Lowes and get 4 long bolts, nuts, and washers.
I tried to be as honest as possible, so whoever buys it knows what they are getting. I have the instructions in .pdf, but Vortech changed the intercooler hose routing and pump location, so I took pictures when I removed it that I can send to the buyer.
I am asking $2900 shipped in the CONUS. You can call/text 910-916-7961 with any questions.
Diablo/SCT Tuner
