W3bb3r04 build thread
awesome car man, sorry I looked in the build thread but couldn't read through that many pages. what cam do you have with the turbo?
W3bb3r04
Slow 3v Member
Clinton, TN
No problem! Its a custom grind turbo cam
W3bb3r04
Slow 3v Member
Clinton, TN
Since the head gaskets looked good and no combustion discoloring on the top or bottom of the gaskets, Im thinking of leaving the heads as is. I plan on checking straightness with a straight edge and feeler gauge. Does anyone know the tolerance for MLS gaskets. I want to say it is .002 or .003. Would it be possible for the coolant to get inside the motor from where is was leaking from the water pump and into the timing cover? Just trying to get all my ducks in a row. Also I am going with the ratchet style metal tensioners instead of the plastic crap...
lito
Caracas, Venezuela
Where did you got to see the smoke coming out?
W3bb3r04
Slow 3v Member
Clinton, TN
I believe its .001-.0015" per 4.0" of head surface man.
Thank you sir!
Just out of the catch can. None out of the exhaust or anything. There was a little bit of coolant in the oil. Only noticeable after draining all the oil out and seeing the residue left over. Anything else to check before putting it back together?
lito
Caracas, Venezuela
Thank you sir!
Oh, ok, then maybe that was it.
BruceH
BBB Big Bore Boss 322
The tolerance is listed in the manual. No more than .001" over a 4" area iirc.
