Winning all kinds of stuff now! lol Congrats.
Hey let me ask you, how reliably does your Stang run using this turbo kit? I know you havent had it on long, but is there anything that you are constantly adjusting or fixing, etc? I wanted to use the same kit on mine, but I am worried about it compromising how reliable it is.
how many miles do you have on your motor? I have 90k...should I be concerned with putting a turbo on?
The reliability is great! The only thing I had to fix was the power steering relocation line. I would disconnect it from the reservoir and twist it to where the stress is pulling it away from the pulley. Mine touched it after 2 weeks and put a hole in the line. Other than that I haven't had to fix anything on the kit (knock on wood) and have put about 2500 miles on it so far!
Did I miss where you discussed how the ground clearance is? (and what springs you run)
The ground clearance is low but I really havent run into any problems (I am on H&R Supersports). The key is that the low points are between the front two tires. The only times I've ever scraped are on places with steep crest like in certain parking garage. Im beyond happy with the kit!
We are making a kit that takes care of all the clearance issues.
Looking good. Let us know how you like the Konis. Im going to be replacing my OE shocks and struts in the next couple of months.
No bueno haha
60 ft 2.28
1/8 ET: 8.41
Mph: 92
It did mph pretty well but as you can see the 60 ft blew!!
Sent from my HTC6435LVW using Tapatalk 2
