K_Brogoitti
Columbia Basin
Vortech will be here friday! So what's the safe limit for power on a stock block with a safe tune? Notice I use the word safe a lot since it will be a couple years before I can replace my shortblock with a forged unit.
Sent from my XT1080 using Tapatalk
Riptide
Will work for Mustang.
Montucky
Very good advice. Over spinning it is no bueno. I kept mine at 6200 or less when I had the 3v 2.6 kenne bell. I was a little paranoid. But it never blew on me..
BleedinBlue
Eureka, Mo
Made my first attempt at paint correction then worked my way up to CG black, Pete's and V07. Not perfect and I didn't get all the swirls, but made a big improvement I think.
Jeffk
Thomasville, NC
Played with a guy in a 3V on my way home from the 50th. My little 2V actually surprised both of us. :)
Sent from my SCH-I535 using Tapatalk
Gabe
Whippled Coyote
Test-fitted and test-drove :D the new 305/40/18 Nitto 555R's
Steedman07
Classified's Moderator:)
Connecticut
Did you heat cycle them? I am getting my 555R's installed this Friday. I have had them before, and they do me just fine.
Gabe
Whippled Coyote
I did not, unless heat-cycling = burnouts, LMAO
How do you heat-cycle them?
Riptide
Montucky
When you order them they can heat cycle the tires before they ship. discounttiredirect offers it.
Heat Cycling
Any DOT race tire is extremely sensitive to the first heat cycle of its use. The first heat cycle can determine performance and wear characteristics. The compounds in a new race tire are “green” and its chemical make up is not fully stabilized.
During the first heat cycle, the tread compound stretches as it heats. The heat can also cause changes at the molecular level. During a heat cycle, bonds are broken and reformed that help to make the tread compound more stable.
The benefit of this process is a tread compound that lasts longer and provides better traction. However, if the first cycle is not performed correctly, the tread may develop irregular compounding, leading to poor wear and inconsistent traction.
Some racers try to heat cycle their own tires, with mixed results. This involves bringing the tires up to race temperatures and then “resting” them for 24 to 48 hours while off the vehicle. This process can be inconsistent as the tires may not heat evenly on the four corners of the car. Also, temperatures across the tread face are not always uniform due to camber and scrub. Plus, if this is the owner’s only set of tires, it is inconvenient to mount and dismount the tires before using them to race.
Some DOT race tire suppliers offer heat cycling services, and use machines that heat the tire by applying a load (no artificial heat). These systems generate uniform temperature build up throughout the tread, a condition not achievable on the track. Because there is no cornering involved, there is lateral scrubbing and virtually no loss of tread during the heat cycling.
foxxxtman
Put up a new shed, cleaned out my garage to make it suitable for the mustang utilizing that shed, power washed/2 bucket washed my car, dried with a leaf blower and then clay barred the entire thing today. It's been a week long process LOL. Coming in the next few days is glaze and wax, O/R-H and a Mike Rousch tune. I've been busy. Crappy picture as it was rainy out almost all day here but it gets the point across.
o2sys
NY/NJ
Installed high flow cats
Didn't feel like welding a new o2 bung this time around so put an AEM noweld clamp
posted via Tapatalk
