Wheel aligment after installing front sway bar
Norm Peterson
corner barstool sitter
RIP - You will be missed
When you reversed the strut mounts to change the cambers, you also changed the toes. If that's when you removed the front sta-bar (which would make sense), blame the strut mount reversal not the bar removal.
Norm
07 Boss
Sin City
Norm
Affirmative. When I turned mine I went and got an alignment to check if it got within spec and they had to adjust the toe a bit but the camber was fine. Now that I have them back to the oem position I bet I should check it again.
RocketcarX
95% of my weight is fuel
Colorado
Norm
I only recently removed the sway bar, the car was in perfect alignment before hand. I'm not blaming anything, only relaying my experience.
